So apparently you cannot scale the range of the modwheel? Seems like a major design flaw...
I was working on a patch today, and even though i turned down the initial amount, turned down the modwheel and removed the lfo amount as a destination for AT, the lfo was still affecting the filter.
When turning up the modwheel, lfo amount jumps straight to max, no amount could be dialed in. Turning the mdwhl down reduced the lfo amount to zero instantly. when i pushed the filter as a destination in the lfo matrix, it instantly started affecting, even tho modweel was completely down.
Is this a bug, am i misunderstanding something, or can it be i have a broken modwheel? maybe the calibration is off, so Mdwhl on zero still gives an lfo amount?
does anyone know of a solution, or calibraton procedure for the wheel?
