I just got my rev2 and am still getting to know it. I've been into synthesizers for a while, so the concepts aren't new to me in general, but the following issue has me kind of puzzled so I was hoping someone might be able to help me understand what's going on.
In the filter section, when you set the envelope amount to a negative value, the user manual states that the velocity knob serves to close the filter more the harder you play, causing the sound to become less bright. But no matter what I do I can't seem to get this result. Starting with an INIT patch, I only made changes to the filter section as follows:
Cutoff: 164
Res: 0
Env Amount: -127
Velocity: 0
Key Amount: 0
Audio Mod: 0
Delay: 0
Attack: 64
Decay: 64
Sustain: 64
Release: 64
Of course when velocity is set to zero, playing the keys harder makes no difference.
But then, as I raise velocity gradually from 0 up to 127, the sound actually gets BRIGHTER when I play the keys harder.
Can someone please explain to me why I'm not getting the results described in the manual with these settings, and also how to achieve the desired behavior just using the filter envelope settings (press keys harder = close filter more).
By the way, I've already updated to the latest firmware, 1.1.0.3.
