I recently noticed that with MIDI multi mode on, if I switch layers (lets say from Layer A to B) while holding a note down, the voice in layer A will keep playing. The only way to then send a Note off signal is to switch back to layer A and play the exact same note, or use enough of the voices to have the one playing reassigned. This is of course with Hold set to off.
Does this constitutes normal behavior? I don't recall this happening, but I have not been using Multi mode often.
