Daft Filter Routing Question
ARNK
  • 124
    • Returning to Zero
« on: January 20, 2018, 05:27:54 PM »
Hey guys, easiest question in the whole of the forum.
If either lights under Filter Routing are unlit, this simply means that every oscillators output is going directly through either Filter 1 or Filter 2, whichever happens to be Enabled. Yea?
Re: Daft Filter Routing Question
« Reply #1 on: January 20, 2018, 06:02:50 PM »
Daft answer: yes.  ;)
ARNK
  • 124
    • Returning to Zero
« Reply #2 on: January 20, 2018, 10:06:40 PM »
 ;D
Shaw
  • 1156
« Reply #3 on: January 21, 2018, 05:53:32 AM »
« Reply #4 on: January 21, 2018, 07:17:49 AM »
Right on! Taking it to the next level.
« Reply #5 on: January 21, 2018, 09:45:56 AM »
Question regarding issue with EL wire in ableton...
ARNK
  • 124
    • Returning to Zero
« Reply #6 on: March 18, 2018, 09:41:27 PM »
Okay, here's one a little less daft. Is it just me, or can you not set the Filter Routing knob to a specific value? Say where 0 - 127 would be 100 for example? As far as I can see, no value changes on screen when setting the mix between serial and Parallel.
Thanks
