Hi, I have not got a P8 and do not use FL but I can try to help.
Let me try to understand whats going on.
If you play the P8 from a keyboard and record the audio into FL then everything is ok?
When you play midi from FL to the P8 the audio is not correct?
Cheers
Andy
Hi Andy,
Yes that is correct, except when I simply just play midi from FL to P8 it works just fine. But I cannot export it as an Mp3 unless I record that midi recording into an Audio clip, so when that takes place I lose detail of the sound after it is converted to an Audio clip.
Would you have any suggestions as to why the P8 loses quality in the sound when it coverts from Midi to Audio? I guess that is the shortened summary of what I am dealing with.
However, Going direct Input route (like you would vocals) the recording of the Audio clip is just fine with no quality loss.
I hope there is a fix to this.
I'm very confused about that "converting midi to audio"..I don't know if i get you right, but it sounds like you are trying to convert a midi file to audio?? this might work if you have a softsynth on that miditrack, but I don't think it's going to work with your P8..
I am not too good with terminology but ill try to explain as accurately as possible.
For example lets say I manually click in A minor chord in a Piano roll editor that is routed to the P8. So what ever synth I have programmed on the P8 will play that A minor chord if i press play button inside the Daw or manually click one of the piano roll notes you will hear the synth being triggered.
This works great and I have no issues, but the problem comes in when I want to export the song as an mp3. It doesent export the synth unless I record this A minor chord patter into an audio clip. The Daw records that manually entered A minor chord into an audio clip file or stem.
Kind of like how if you had a cpu intensive vst instrument. To clear up ram and space you would convert that digitally recorded pattern to an audio clip/stem and then delete the Vst instrument to clear up space. The stem that you converted from the vst still has his characteristic and everything. With the P8 after i record it as an audio clip from the digital recording(MIDI), i lose quality in the sound or maybe details such as decays and delays that were originally part of the tone of the sound.
Sorry i'm not sure if that helped but please ask any questions ill try my best to explain in more depth. Its one of those tricky but potentially quick fix type problems lol
