There should be two sets of banks which are identical User (U) and Factory (F). They are both identical coming from the factory. Only the user banks are re-programmable. If you do not want the sound you programmed into the user bank and you want the original factory sound, you can go to the factory bank and pull up that sound, then save it to corresponding user bank.
