Last patch used on start-up
« on: December 24, 2017, 11:37:54 AM »
Hi, I've looked around on the forum (maybe not hard enough ?) but I didn't see this info, could anyone tell me if it's possible to have the synth power-up with the last patch used ? Mine always reverts to U1 P9 when powering it up.
Thanks for any reply.
jg666
  • 484
Re: Last patch used on start-up
« Reply #1 on: December 24, 2017, 11:53:17 AM »
I know you can change the patch that it starts up with by doing this...
Select the required patch
Go into Globals
Exit from Globals
Power the keyboard off.
It will then start up with that patch.
I’ve not seen an option to make it start with the last one used though.
« Reply #2 on: December 24, 2017, 02:11:29 PM »
Go into Globals
Exit from Globals
These two steps are the right way. I was told that this was done to save the flash memory which has a limited number of write cycles. Not the last patch is always saved, it is the patch which was active when looking into the globals.
DSI Prophet Rev2 | Moog | Roland | Doepfer
« Reply #3 on: December 24, 2017, 03:03:41 PM »
Go into Globals
Exit from Globals
Ah, thank you both for the info. I didn't see anything about that in the manual...
 :D
jg666
  • 484
« Reply #4 on: December 24, 2017, 03:51:22 PM »
Go into Globals
Exit from Globals
 :D
I don’t think I saw it in the manual either, I think it was on these forums that I saw it. If I remember correctly I probably did this accidentally and couldn’t work out how I’d managed it and did a search here !!  :)
