Is this a bug?
For example, the setting:
My externel sequencer sends MIDI-notes only on channel 1.
My Rev2 is in Multi Mode, the base channel is set to 1, so that layer A receives the notes from my external sequencer, and layer B is automaticly set to channel 2.
So far, so good. BUT: When I switch on "Edit Layer B" and then press "RECORD" the incoming external MIDI-notes rush in to the recording of layer B! - although this should only receive signals on MIDI-channel 2!? Right?
("Stack A+B" is not activated; "Split A/B" doesn't seem to have any impact on this issue weather activated or not)
That means, that - while layer A is receiving external MIDI-notes -:
a) I can't record a Poly Seq on layer B
b) - more worse - I can't even transpose a (before recorded) Poly Seq on Layer B, as this also requiers a (short) pressing of the RECORD-button, and that causes that the incoming MIDI-notes on channel 1 are mixed with the key-note I press on the keyboard intending to transpose the sequence. The result of the transpose is therefor messed up.
Do you know what I mean? I'm I overlooking something?
