So true as well, Soundquest. It's tragically the case that many people now experience life primarily through a screen and through others. You can watch hiking videos all day on YouTube, but that's not hiking There's nothing like the real thing, like hiking the Appalacian Trail for yourself, coming home with a few cuts and bruises, and a head full of wonderful memories as well. That's real living.
Even in this highly technical field of electronic music, one has to draw a line. You can spend most of your music time watching videos of other people making music or demonstrating equipment, together with reading the views of other people on forums and expressing your own. It gradually becomes an end in itself, so that most of your synthesizer activity consists of this passivity. It's crazy. I found myself prone to this, and so I've had to gradually wrestle my way off a number of forums. This is now the only forum I post on or even read, and I've drastically cut back here as well.
The virtual world is teeming with viewpoints, comments, and rumors. So much of this is inaccurate or plainly erroneous - as we've just recently been reminded. And in terms of advice, people often suggest that you do what they would do if they were in your situation. And that's terrible advice. I've found that, when making decisions about equipment, I've usually had to go against the tide and do what others thought ridiculous and said I should not do.
The best solution at decision-time is to withdraw from all the online chatter, carefully think things through, and then make a decision based on your own intelligence. Spend research time carefully examining the piece of equipment on the company's website. That's the most valuable research. But if you seek a lot of advice on the forums in making decisions, remember that there are heaps of bad advice to be found, and often this bad advice is the most loudly expressed of all.
My personal solution has been to spend much less time on forums and YouTube, and more time at the instruments. If I need information, I go directly to the source - the company or store website. The time available for music-making should be spent, not obsessively researching equipment and sifting through masses of opinions about it online, but actually making music with the equipment you have.
