My questions:
- Do you think DSI will implement a partial local control off in the future? So that only the keybed is disconnected from the local control but the knobs/modulation controlled internally? That would solve the problem in an easy way.
Thanks in advance for any input. I'd really like to find some kind of solution to this. Frustrating!
I asked for partial local off control two years ago.
https://forum.davesmithinstruments.com/index.php/topic,157.msg1319.htmlThey didn't change the local mode since then so I don't have much hope they will implement it ever.
Though it is still my main grief with the P~6 and one reason I did not buy the OB6.
I was using the same "workaround" like you: set the P~6 *local on* and turn down the volume every time when "remotely" playing other instruments.
I also informed me about other options:
there a multiport interfaces with programmable MIDI filters and routing options available.
The idea is to connect the P~6 solely to a single port.
Then you can set the P~6 *local off* but permanently filter and reroute the NRPN data (knobs and buttons) back to itself in the interface.
But all this is error prone, expensive and too complicated for me so my sad solution at the end was to give up and use an other synth for *Master Keyboard* purpose.
