Hi guys,
A newbie here:)
I am trying to record a sequence. To keep it simple i try to record all the (white) notes from C3 to C 4.
I would expect the sequencer should play all the notes successively but it doesn't. It sounds like it gets stuck playing only two notes going up down..
Changing the note value does not change this, it just changes the timing off course. Should I alter a Global setting or something to enable the use of the 64 steps?
Thanks for reading!
