Hi, new owner of a REV2-16 here. I was wondering if there's a way to have a global LFO, meaning that it would act like a single LFO for all voices ? Aside from using the Key Sync mode ? I didn't see anything about that in the manual.
Hey there, the short answer is no.
But there is a pretty good work around that you can read about here
http://forum.davesmithinstruments.com/index.php/topic,2027.0.htmlor the TL;DR method to get them synced:
-press unison button while holding misc params (this is shortcut to that area in menu)
-turn unison mode to all of your available voices (8 or 16)
-turn on unison
-turn on key sync on lfo then press a note. The lfos are now synced.
-turn off key sync and turn off unison
-this should work exactly like what you are looking for.
This works because you are using unison + key sync to trigger all voices at once (and by consequence, their lfos.)
When you turn off keysync and unison, the lfos per voice are now freely moving yet they are still running in tandem from the syncing we did. Since are digital, they should stay synced for ever and function as the global LFO across all voices.
