What exactly is the setting you need to do in order for a sound to trigger when you release the keys? Is it a negative envelope? I want to be able to press the keys and get a sound and then when they are released it triggers a quick staccato note.
and then this one
It sounds like when a key is pressed the note sounds but then when it's released an LFO kicks in.
Can anyone assist me?
Don’t know how much help it’ll be but ,
The EGs ADSR Is going to be an important part. If you have the release set past what the respective attack level is , then it won’t trigger or morph back into the other sound .
Try this for an example , feed your filter to your EG, turn the attack to noon and release to 3pm. Play a key , and then fool around with those two knobs .
Hope I’m not wasting your time .
