Big Skinny Puppy fan, saw them three times live and even have a pic with Ogre & me on it
The Kraftwerk stuff I thought it probably could/would be a lot of virtual synth stuff.
Saw some of your videos on youtube before I got here
Thanks for watching some videos!
To return to the original question: The songs and styles you were referring to are of course very widespread. And anything in the Skinny Puppy area would of course require a sampler or at least some sort of hybrid synth like the Prophet 12 or Pro 2.
Beyond that, both the Sub 37 and the Rev2 would certainly be adequate choices for what you like. As everybody has already pointed out the obvious differences between both, you should follow your ears. Find a store in which you can try out the Rev2 as well. Go back and forth between it and the Sub 37. Also ask yourself what tasks a new synth should cover for the most part. Is monophonic/paraphonic enough? Which synth just feels better to you? What elements of those you'd like to focus on come across as more convincing in terms of usability (e.g. arpeggiator, sequencer, modulation section, etc.)? And so on.
The more REV2 demos I hear the more I lean to it, it is a more complete synth in the sense of 5 octaves, split or layer built in FX and the sequencer has advantages as disadvantages over the Sub. If I figured correctly it can record realtime parameter (say filter sweeps) editing and get that into the sequence.
at 21:40 and 25:48 are the moments I was hoping for.
I really like the thinner sounds it can make, but it can make those big boiiiiiing boiiiiing sounds too
The Moog is like omni present and I read this before can be a bit hard to get into the mix. The DSI so it seems is a bit esasier.
Thanks a lot, yes of course before buying I will noodle on the DSI as well.
There is a lot to play with, 4 LFOs and 3 envelopes...and the rest.
Getting more convinced now that I heard the REV2 can have this bottom end.
