OB-6 editor VST
OB-6 editor VST
« on: November 14, 2017, 06:28:01 AM »
Hi there,
I released OB-6 VST editor. Now you can store your patches within DAW project, automate synthesizer parameters and much more!
Product page: http://codeknobs.com/products.php?id=9
Re: OB-6 editor VST
« Reply #1 on: November 14, 2017, 06:30:05 AM »
Currently only windows version. Mac version is comming soon!
Re: OB-6 editor VST
« Reply #2 on: November 23, 2017, 08:33:44 AM »
Black friday sales available!
Re: OB-6 editor VST
« Reply #3 on: March 02, 2018, 11:25:23 PM »
Version 1.9 released!
Changes:
- Polyphonic step sequencer control
- Aux output port. Now you can record MIDI from synthesizer in DAW. On Windows platform it requires virtual midi ports software.
- Fast program recall. You can easy bind 5 programs to buttons on toolbar and load them in editor by one click.
- Dynamic changes parameters names in FX section.
- LFO FREQ and DELAY TIME in synced mode now shows bpm synced values.
- Improved performance
- A lot of minor bugs fixed
Re: OB-6 editor VST
« Reply #4 on: June 05, 2018, 02:16:49 PM »
NEW VERSION 1.15 RELEASED!
New features:
1. Input Clock midi port. Now you can route MIDI clock and sync messages from DAW to synthesizer to sync arp and seq.
2. Latency parameter in preferences. Now you can set latency between playing note and signal on audio interface. Сhanging this parameter requires disabling and enabling the plugin instance.
3. Delay parameter in preferences. Sets delay for playing sequence, Can be useful for sync DAW and synthesizer when audio signal doesn't captures in audio interface in DAW and routed to console etc.
4. Sidechain audio input. Now you can route audio data to the editor, it can be useful in some DAWs when you want to process audio on channel with the editor.
Fixes:
- Fix plugin audio output. Now it is stereo.
- Fix issue with displaying VST in Studio One 3 and 4
- Different minor fixes in layouts
Re: OB-6 editor VST
« Reply #5 on: September 28, 2018, 07:26:41 AM »
New version 1.16 released!
Changes:
- Fixed issue with Param Xmit and Param Receive options.
- Reduced video memory usage
- Minor fixes and changes
Re: OB-6 editor VST
« Reply #6 on: November 22, 2018, 06:30:17 AM »
Black Friday sales available?  :)
Re: OB-6 editor VST
« Reply #7 on: November 22, 2018, 09:22:29 PM »
I was hoping for that all year.... :o
Re: OB-6 editor VST
« Reply #8 on: December 28, 2018, 11:42:43 PM »
X-MAS SALES! OB-6 editor just for 34$!
http://codeknobs.com/products.php?id=12
Re: OB-6 editor VST
« Reply #9 on: March 26, 2019, 03:52:09 AM »
I updated user manual and added few paragraphs:
  • How to capture audio from synthesizer in DAW and process it on same track with the editor.
  • How to record MIDI from synthesizer in DAW.
  • How to sync BPM, work in slave mode.
Hope it will helpful for users.
https://codeknobs.com/how_to_configure_v3.php#capture
Re: OB-6 editor VST
« Reply #10 on: March 31, 2019, 03:41:33 AM »
Thanx for that! Can we upgrade to firmware 1.5.8 or is that too ealry for your software version? I ask for the portamento / rate sending CC5 bug.
Re: OB-6 editor VST
« Reply #11 on: October 07, 2019, 08:23:03 AM »
For a long time I did not publish news about updates. So... :)
New version 1.23 released!
Changes:
- Minor fixes and improvements
BTW. On my opinion the editor should be pretty stable and bugs free. I use it every day in my production. If you unlucky tried it sometime ago then try it now. But don't forget to properly configure your setup by this article https://codeknobs.com/how_to_configure_v3.php
Re: OB-6 editor VST
« Reply #12 on: November 27, 2019, 08:07:35 AM »
Black Friday Sale!
Re: OB-6 editor VST
« Reply #13 on: May 31, 2020, 02:57:47 PM »
Is there any way to play in or step enter into the sequencer, or do you just have to select note by note?
Re: OB-6 editor VST
« Reply #14 on: June 15, 2020, 03:10:38 AM »
Unfortunaletly there is no way to do this in the editor.
Re: OB-6 editor VST
« Reply #15 on: December 30, 2020, 12:42:01 PM »
hi,
The VST editor works great! I just have a couple of questions:
What is the ideal way to send MIDI notes? My OB-6 is connected via USB, but I had to disable the OB6 as a device in Ableton so the VST would take over the ports. But then how do I send MIDI to my OB-6? My audio interface doesn't have MIDI outs, so I was using USB to send notes.
I plugged in a separate MIDI interface, and am sending notes via MIDI cable to the OB-6, while the editor is working off of USB? Is this the intended functionality? Seems to work fine, just a bit annoying.
What's the best way to handle multiple instances of the editor? Should I make a patch, record audio, and then disable the VST instance? Then create a new channel with a new editor for other sounds?
Let me know your thoughts.
Re: OB-6 editor VST
« Reply #16 on: January 10, 2021, 11:46:43 AM »
Yes, that is one option, you can also use LoopMidi software to make a virtual midi cable that will be recognised by your DAW. Choose that cable as an input for your track with the editor loaded on it and also select it in the editor preferences under aux output port:
I have another question about the PROGRAMS part. I can load ob6 presets and downloaded files into the database but is there a way to save your database or export tab to disk?
« Last Edit: January 10, 2021, 11:50:21 AM by Knob twiddler »
