Hi!
I just noticed that the codeknobs editor does not seem to send any parameter changes anymore to my REV2 when used in Logic Pro and when I turn a physical knob on the synth.
I have set up both the REV2 and the editor software according to the setup instructions and disabled the Rev2 midi port in Logic and instead enabled the ProhetREV2Editor_AUX midi port.
If I turn a knob with the mouse in the software editor, for instance the cutoff, then the sound is altered in the synth, but if I turn the physical knob on the synth, then I can only see the knob turning in the editor, but the sound is not altered. So the editor does only seem to recieve parameter changes from the synth, but not send them out.
This has worked fine before, so it's strange it suddenly stopped working. Any suggestions what the problem might be?
