What settings did you use to get it to work on the gated seq? I couldn't get it to work, as I described a few posts ago. I still got the effect that every note would stay in sync to it self in time and not aligned on the beat in tempo
I never actually did this with gate seq. I was going off what I heard from other users. I haven't messed with gated seq much at all. I just tried myself and can confirm, it also appears to be per voice.
An interesting fix DSI could add is giving us a second LPF as an effect. Even if its digital, it would allow us some cool combinations by using two LPF in a patch and it would also allow us to modulate this new filter in a sort of mono way that wouldn't trigger per voice.
Or even an option in misc parameters that would set the LFOS to be truly locked and synced when using click sync.
In the meantime, I'd still say play with LFOS on some of the effects because they are on the master sound output and not per voice.
Experiment a bit and I'm sure you could find something close. Try this real quick. You don't even need LFO.
Use ringmod effect with mix on 100% and both parameters all of the way down. You don't have control over the speed, but its a nice quick and dirty gated style effect.
EDIT: I re-watched the example video you provided and its very possible to achieve this even with the REV2. The playing in that video is pretty lined up. Just set your LFO to whatever you want, turn on key sync and make sure to press keys at the same time and you'll have the effect in that vid.
https://photos.google.com/share/AF1QipNfq2nuBfAXPJo_r7pTsJuBDrJetEzaZhnXbqyAebu0xMk6L4EPWKU782sXji2URg?key=SG5nWXFjRjZ1TE1VLWdLUzlBbmJwVGtDM3VWZVpBI've achieved it here by using a Reverse Saw LFO on cutoff freq. Just key sync it, play in time and your golden.
