https://www.modulargrid.net/e/racks/view/536104
People love the Erica stuff, it has a great reputation. With this particular system, a few comments would be:
(1) You've got a ton of sound sources (2 VCOs, the suboscillator expander, and the wavetable oscillator), but no way to mix their outputs before going to the filter.
(2) You'll want some utilities like attenuators, scalers, inverters so that you can control your CV. Think of these as the "amount" values on a DSI modulation matrix. You might want a
subtle vibrato, for example, which would require attenuation of the CV output from an LFO.
(3) You want the Black 8-Multi there to direct CV to your oscillators; but the Pico Multi won't be that useful in 107HP. Get a few stackable cables instead to free up some space. An extra VCA would be a good candidate for that space (see below).
(4) Eurorack enthusiasts commonly say "you can never have enough VCAs." I think this is nonsense, and there's definitely a sweet spot. You'll want more than the two you have, though. If you can get VCAs with level knobs (unlike the Pico, which just has one CV in per VCA), they can pull double-duty as attenuators. Double duty is gold in a small system.
(5) Speaking of double duty, you can economize (space-wise, I mean) on VCOs. For example, you can find VCOs that have suboscillators built in and/or VCOs that can function as LFOs (which is a Model D trick). The Intellijel Dixie II+ is a great candidate, as it does both of those things. That said, I think that oscillator choice is the most important part of a eurorack system, so make room for the oscillators you really want rather than compromise with something that ticks boxes.
(6) Lots of folks would recommend a Disting. While Disting isn't my cup of tea, a good case can be made that it lets people figure out what dedicated module they really need based on what they use Disting for.
For the most part, you're on the right track. Mostly, you need to use what you have, and that will guide how you shift things around. Probably very few initial plans go unchanged as people learn more about what they want to do.
Yeah, Mantis + Pro2 would be a great way to go.
This is going to get expensive....
It could, but you shouldn't buy it all at once, is the nice thing.
Any suggestions for a good 1/4” output module
I wish I could find an extra 2HP for a Make Noise Rosie for its effects send. I have the Pittsburgh Modular Outs, which is nice, but I'll probably replace it with an Intellijel µJack for its mono mode.
sequencer module
Hard to give advice there. Like oscillators, sequencer choice is very personal. There are full-featured sequencers with memory and 64 steps, and simple sequencers with 8 steps that just go in one direction. My choice, Moskwa, was on the simple side. I love how it's laid out and how immediate it is.
and MIDI to CV module. On the MIDI to CV module, I am thinking of the Mutable Instruments Yarns because it integrates a pretty good arpeggiator, but suggestions are hereby solicited and appreciated.
Yarns is probably one of the best if you're going with straight MIDI from the DAW. Another option is a DC-coupled audio interface with Expert Sleepers's Silent Way software, which lets you send CV directly from your DAW.
I don't have a MIDI module in my synth, but I can convert MIDI to CV using one of my keyboards (the most flexible of these is QuNexus), and CV to MIDI with an Arduino-powered box that I designed. There's no shortage of ways to interface eurorack and MIDI.
Hope you have fun!
