Weird autopanning issue from the main stereo output, help needed.
Hello
the Tempest drum machine that I have been using started to show a weird trait.
When I play something from the main outs, for example a four-on-the-floor bassdrum, every fourth hit comes from the left output ONLY.
And yeah I have double checked that no sound has been assigned to the other voice outs. And that the sound is panned "C".
Here is a soundclip to demonstrate the issue:  https://soundcloud.com/user-440547962/kick-drum-issue
All help is much appreciated since this problem is quite very annoying.
-djruubio
Re: Weird autopanning issue from the main stereo output, help needed.
« Reply #1 on: October 29, 2017, 09:45:17 AM »
Hi and welcome to the forum ;)
We advise any new users to check the FAQ thread on how T’s voices work...
https://forum.davesmithinstruments.com/index.php/topic,78.0.html
« Reply #2 on: October 30, 2017, 10:34:01 AM »
Thank you very much Yorgos, but surely it should not sound like that from the headphone output also?
With every other hit coming from just the left headphone speaker.
« Reply #3 on: October 30, 2017, 10:37:03 AM »
Yep it also applies to the headphone output ;)
As soon as you plug a cable into a voice out that voice disconnects from everything.Does this happen even if you don’t have any cables plugged into a voice?
« Last Edit: October 30, 2017, 10:41:55 AM by Yorgos Arabatzis »
« Reply #4 on: November 07, 2017, 07:46:26 AM »
Yes, like I said in the first message, It does the same kind of weird thing even though I dont have any cables plugged into a voice. And none of the sounds are assigned to a voice out.
« Reply #5 on: November 07, 2017, 09:04:10 AM »
I'd check voices one by one if I were you.The symptoms I heard in the Soundcloud clip is either like is something connected /stuck in T's inputs or an external message changing panning or an LFO or something in Mod Matrix changes panning..
Are you using T standalone or is there something connected to it?
« Reply #6 on: November 11, 2017, 10:15:03 AM »
I'm sorry Yorgos but all this has been checked multiple times. I'm not new to this machine and I have a solid understanding on how it works. There is something really wrong with the machine, otherwise I would have not written this article on this internet message board...
« Reply #7 on: November 11, 2017, 10:53:52 AM »
Have you contacted support?
« Reply #8 on: January 26, 2018, 08:00:07 AM »
I'm having the same issue, did you manage to figure this out?
Thanks
Lukas
« Reply #9 on: August 10, 2018, 11:30:25 AM »
Thanks
Lukas
Having the same issue, anyone fix it?
« Reply #10 on: August 10, 2018, 11:47:12 AM »
Hello
-djruubio
Actually I fixed it. I recalibrated my tempest with one lead in the L channel and got like you say the weird panning effect. take everything out and calibrate it with no leads it.
Seems to work fine now
