I see... There's an old trick which could be done with many if not every classic drum machines - you program your beat, and after send midi out to a poly synth. After you program midi note for each drum pad, the results are always inspiring, musical, and sometimes it's impossible to reproduce it in another way. You can also mute some of the drum sounds, but still have midi note on the output, and so on... Very simple but effective technic.
