How to Set Modulation of OSCs Freq Greater Than 8va?
« on: October 26, 2017, 11:55:24 AM »
Greetings!
How do I set the modulation amount of OSC frequency by slider pressure to affect a range larger than one octave? I'm looking for a wild effect similar to wiggling the frequency knob on a modular (or Roland FA 08 will do this). Or am I going about this in the wrong way?
Thanks,
E. Nicholas Morgan
Re: How to Set Modulation of OSCs Freq Greater Than 8va?
« Reply #1 on: October 26, 2017, 10:01:52 PM »
You can double the modulation by just adding the same path&source&amount.
« Reply #2 on: October 31, 2017, 08:46:02 AM »
If I start with Basic Program, and I select mod source as slider and destination as all osc frequency, and I put it in there twice at amount 127, I don't hear an increased range. Is that what you meant?
« Reply #3 on: October 31, 2017, 11:04:26 PM »
Add the same source, amount and destination twice as another modulation path. Double it! Triple it! Quadruple it!
« Reply #4 on: October 22, 2020, 03:47:14 PM »
It doesnít work with envelopes neither lfos.
I have the same question.
I want to do some radical sync sweeps but it seems impossible.
I donít have my P12 near me now, but Iíll try with modwheel tomorrow.
Itís really frustrating the low range when using an envelope or lfo to modulate an osc pitch.
Can someone help?
« Reply #5 on: October 23, 2020, 08:25:06 AM »
Iím sorry but stacking modulations doesnít work (at least on my unit Prophet 12 Module).
iíve tried everything and the only improve was with 2 of the same lfos but it was a shy increment. when using the same lfo for the third time, there was no improve.
it doesnít work with the modwheel neither envelopes.
I wonder if itís because weíre modulating osc frequency and not osc pitch (there is no osc pitch as a modulation destination).
can someone post a video or sound example?
« Reply #6 on: October 23, 2020, 08:25:49 AM »
Iím sorry but that doesnít work (at least on my unit Prophet 12 Module).
can you post a video or sound example?
« Reply #7 on: October 23, 2020, 08:26:52 AM »
« Reply #8 on: October 24, 2020, 01:28:47 AM »
second mod slot doesnt go over the first ones max. Second LFO synced to the first doesnt work either here but Env3 in repeat goes higher.
Hope this helps somehow,
Martin
« Reply #9 on: October 24, 2020, 07:16:54 AM »
Martin
thanks!!
iíll try that tomorrow.
« Reply #10 on: October 25, 2020, 04:45:01 PM »
Martin
it didnít worked...
