Hello all, first off, thanks for welcoming me to the community. I just got a Prophet 6 and I'm having a blast. Looking forward to contributing to the community in any way that I can.
I'm having a bit of a problem with the sequencer.
I want the notes to run into each other so that they sound legato.
There is a pause between each note or chord in the sequence as it stands now. I understand how to tie notes or chords together as well as how to change the note value but this is something different. I also understand that I can increase the release but this is different as well. Assuming that I have a long sustain, shouldn't the chords/notes run up against each other?
The following all applies to Poly mode because I hardly ever use Unison mode (maybe I should try some of those sounds!)
I've just tried it on my Prophet-6. I already know it can be done on the P6 arpeggiator easily by adjusting the amplifier and filter envelopes especially the releases to make them longer because I never stop playing with the P6 arpeggiator, which is more useful than that on the OB6 because the OB6 has one annoying omission, that is playing a given note twice in a sequence.
So after trying the P6 sequencer, I think the answer is YES, as it is with the arpeggiator. Setting the release time, particular on he Amp envelope to be quite high, you can get a polyphonic effect because you hear the releases of the last 6 notes, which is really very cool and one of my favourite things about playing the synth. This is even though the arp is essentially monophonic, you still get the poly effect because of the release tails (and also from any digital delay / bucket brigade delay echoes).
https://www.youtube.com/watch?v=mJKWMhDa8oY&list=PLkDrBr6YDpo5MvG_DZFYHXPsBxbl7mUI7&index=9&t=0sMaking a lot of noise! :-) Jamming on the arpeggiator with lots of resonance!!!
OK, then these, much more subdued:
https://www.youtube.com/watch?v=24SJJLvJlU4&list=PLkDrBr6YDpo5MvG_DZFYHXPsBxbl7mUI7&index=2and
https://www.youtube.com/watch?v=cp9ReaQyhas&list=PLkDrBr6YDpo5MvG_DZFYHXPsBxbl7mUI7&index=1without HOLD on the arpeggiator, the others had "hold" on so I could piddle around with the panel controls.
Great thing with the Prophet-6 is then you can do filter sweeps onthe "chords" even though the arpeggiator is monophonic. Of course the sequencer is polyphonic but I like the arp more because you can just play it live without recording and playing back.
If you have no release time on, the "gate time" of each note on the arpeggiator or sequcner sounds like about 50% of the beat. Not sure if this varies with the tempo or not. Obviously though, the slower the beat otr tempo, the more likely a given sound is to die away before the next note is played so for slower tempi, you will probably need more release time to sound legato.
Another thing is that if you have quite a lot of filter envelope amount and a filter envelope with short decay time or an amplifier envelope with short decay time (and attacks on either) with the SUSTAIN KNOBS set low, the sound will be more staccato as well.
Set an arpeggio going on hold or record a sequence and have a good jam playing the envelope controls and the filter env amount knob on the low pass especially. One of the great things about the P6 is that both filter and amp envelopes are one above the other and you can instantly compare them and see how they compare with each other when you're making, or just finding by accident various sounds. The same is true for the OB6 layout in this regard.
