using P12 polyphonic pressure with Roli Rise
W07
« on: October 07, 2017, 05:53:56 AM »
So i've just bought a Seaboard Rise and i'm trying to set it up with the P12 but i'm not quite sure what settings to use.
So far it seems to respond to channel presure only. Anyone else who's had experience with this?
I had to use a max 4live device to change the standard slide CC in Live, i haven't found a good device to offset and scale the cc range, so it doesn't start at value 64 by default.
Any tips or advice welcome!
Off topic, i've recently acquired a MF108 Clusterflux as a send effect, and the noise & warmth of the bucket brigade chips and drive circuit are the best warming/fattening trick i've ever come across for this synth...
Re: using P12 polyphonic pressure with Roli Rise
« Reply #1 on: October 08, 2017, 04:06:06 AM »
I have never had a problem with poly pressure on the P12.
Are you sure the Seaboard is setup correctly to send it?
P.s if you are going through live it won't work, live doesn't support poly pressure and filters it out!
