Manual Error: Delay 1..4 Pan NRPN Codes
« on: January 05, 2016, 10:32:13 AM »
FYI:  I was setting up my Behringer BCR2000 to control the P12 Module via NRPN codes and the codes associated with Delay 1 Pan through Delay 4 Pan in the manual are off by 2.
The manual shows:
Delay 1 Pan - 427
Delay 2 Pan - 428
Delay 3 Pan - 429
Delay 4 Pan - 430
The actual mapping:
Delay 1 Pan - 429
Delay 2 Pan - 430
Delay 3 Pan - 431
Delay 4 Pan - 432
Guess I should also send an email to DSI support  ;)
Re: Manual Error: Delay 1..4 Pan NRPN Codes
« Reply #1 on: January 05, 2016, 10:52:03 AM »
Yep I think things moved around a bit in the latest release (Razmo knows the details and will probably pop along soon) and the manual has not been updated, send them an email.
dslsynth
  • 1036
« Reply #2 on: January 05, 2016, 10:58:16 AM »
Not to worry! That table is full of errors, unfortunately. The BPM NRPN numbers are incorrect too.
Checked with the auto generated doc I am hacking on and the NRPN numbers you found are the same as in my table. Time will tell if DSI wants to use it though as a bash/gawk/sed script may not be high on their wish list. But its getting there.
@BobTheDog: Not sure if anything have been moved around in the program vector besides potentially in one of the development releases. What have changed is the addition of new parameters and some of the enum types.
#!/bin/sh
cp -f $0 $HOME/.signature
