I know this should be easy but I just can't nail it on my 08.. its the theme tune to the film Mullholland Dr.
Anyone with any tips how to recreate this synth sounds (particularly the high register)?
Any help welcome! Cheers.
I think the Prophet '08 could create this patch just fine, but it's too complicated to describe every detail of the patch. In general, I find the key to this sort of realistic string patch is in adding a delayed vibrato (although there doesn't seem to be one in the above patch) and a very subtle and slow opening and closing of the filter through the envelope, with the filter sustain set to zero. The 2-pole filter setting is often preferable to the 4-pole, since the former is gentler and the latter sometimes a bit too harsh. It also helps to combine one oscillator of PWM (the rate set according to the lowest note used) with one oscillator of sawtooth, and to use an LFO to very slowly and slightly modulate the filter during sustained notes/chords. Other than that, the Release times have to be set to suit the music that will be played. There's no such thing, really, as a general string patch. You've got to adopt it to the music.
