Hi All,
I fired up my Pro-2 today after a few weeks of not using it much, and to my surprise it's not outputting any sound. So far I have:
- Twiddled every knob, and pressed every button
- Made sure Local Control is ON
- Made sure Show is OFF
- Reseated all the internal cables
- Powered it off for a while and powered it back on
- Tried both L/R outputs and headphones with multiple cables
- Removed USB/MIDI, and also tried sending MIDI notes
- Verified MIDI is being sent from the Pro-2 as normal
- Verified MIDI is being received by the Pro-2 as normal (set sequencer to Key mode, sent notes)
- Updated OS to 1.3
- Reset globals
- Emailed DSI support
I'm pretty sure this is gonna be a support issue, and will probably involve swapping boards or sending it in. But in the meantime since i hadn't found any other such posts about mysteriously silent Pro-2s I thought I'd start one.
Any suggestions?
