Do you think the Prophet 6 is better than '08 when it comes to creating quick sounds ? I wanna try and combine prophet 6 sounds with the Moog minitaur bass together and see how that comes out
The Minitaur would work well together with either the Prophet '08 or the Prophet-6. If it's about creating sounds quicker, the Prophet-6 might be for you. But depending on your needs you should also consider that it offers considerably less options in terms of modulation. It's a much simpler synth compared to the Prophet '08. So with regard to its functionality, it would only make sense to get one if you want to minimize parameter choices in favor of your workflow. Beyond that, you should just check one out in a store to find out if it suits your sonic needs. After all, the Prophet '08 and the Prophet-6 sound different from each other - not like night and day, but different enough. Since sound should be the number one deciding factor for any instrument choice, this is really the first thing you should do.
I did sell my Prophet '08 for the Prophet-6 because I preferred its sound over the former. As for its limitations or its more conservative engine, I also have to mention that I deliberately chose the Prophet-6 as a counterpart to my modulation heavy Pro 2, not because I prefer less synthesis choices in general. Despite the Prophet-6 being a relatively simple synth, though, it has to be pointed out that it's far more capable at producing a wide range of sounds than one might imagine by just looking at its front panel.
