UPDATE!
Got this very helpful bit of info from Carson @DSI. Also, some very helpful insight on folks who are new to using NRPN like me.
Hi Adam,
Thank you for your inquiry, I would be happy to assist in answering your question.
The NRPN assignment values are as follows:
Poly Seq PLAY:
Cc 99 value 32
Cc 98 value 92
Cc 6 Value 0
Cc 38 value 1
Poly Seq STOP:
Cc 99 value 32
Cc 98 value 92
Cc 6 Value 0
Cc 38 value 0
You might also find the below information helpful in the future for determining the value of any NRPN messages you wish to send to the synth.
To send an NRPN to our synth (or any other device) you’ll see 4 MIDI CC messages per change. Here’s an example change using the LFO1 parameters, note that some values are in hex code in the format 0x##:
The value for LFO Frequency is 37 according to the manual 37 = 0x25 in hex (octal) code. Double check to see which your controller uses, this could easily cause confusion. If your controller sends 0x37 instead of 37 you would see LFO 4 Mod Destination changing since 0x37=55
Status Data1 Data2 Event
0xB0 0x63 0x00 NRPN MSB
0xB0 0x62 0x25 NRPN LSB
0xB0 0x06 0x01 Data Entry MSB
0xB0 0x26 0x13 Data Entry LSB
Our synth sees this as a change to the NRPN value 0x25 (Which is 37 in decimal, per the manual LFO1 Freq) and sets it to the value set by MSB (Most Significant Byte) and LSB (Least Significant Byte). When doing a conversion:
(MSB * 128) + LSB = Value
Using the case above:
(0x01 * 128) + 0x13 = Value
Then convert all hex to decimal:
(1 * 128) + 19 = 147
If you are using a relative controller like an endless knob without a led status ring you’d probably want to set it to send NRPN Increment/Decrement messages:
0xB0 0x60 (0x61) 0x00 NRPN Increment (NRPN Decrement)
You can look at this 3 part blog post on NRPN written by our lead software engineer:
NRPN Basics
Hope that helps! Thank you for supporting DSI and have a nice day!
Thank you,
Carson
Dave Smith Instruments
