Keyboard needs repair
« on: August 31, 2017, 01:16:48 AM »
Hello
Two of keyboards have a problem.
I moved back to South Korea, so i think it will be hard to ship it to sanfransisco.
Is this going to be easy fix?
If I can do it by myself, i am willing to do it but Im little worried that if something goes wrong with after touch.
And, what brand key should I buy?
Need only two white keys. Are there any specific model for p12 key?
Thanks in advance!
Best, Q
Re: Keyboard needs repair
« Reply #1 on: August 31, 2017, 05:30:26 AM »
Hello
Nope, should be easy. The DSI units tend to be very easy to disassemble and service. Check in with DSI Support to get the parts you need.
« Reply #2 on: August 31, 2017, 12:30:07 PM »
Sorry to hear you're having trouble with your Prophet 12! As DavidDever points out, it should be a relatively easy fix. If you're the DIY type you may even be able to glue the keybed frame back together for a permanent fix, which would mean you wouldn't have to go anywhere or wait for parts.
It's also relatively easy to replace the keybed, the only tool necessary being a screwdriver. Please contact our dedicated support channel and we'll help you out with info on assessing the damage/repair or replacement: support (at) davesmithinstruments.com
SEQUENTIAL | OBERHEIM
« Reply #3 on: August 31, 2017, 07:31:55 PM »
Thank you everybody!
I just sent an email with images.
If I can do this by myself, I'll upload the process with few pictures.
