I'm not certain if this is a mistake by DSI or what, but one thing that is constantly annoying me is that if I have a program which is a stacked program, then I want the poly sequencer to record into BOTH LAYERS at the same time... currently, you have to record the same sequence twice, once for each layer which is not only tedious and trivial, but also impossible since it's basically not possible to record them with the same velocity values.
A stacked program are meant to be used as a "single program", so it is only logical that it should play the same sequence with the same velocities.
If I press and hold the "Edit Layer B" button so that it flashes for editing both layers, then I am not able to initiate the record button at all...
Summa Summarum: I'd REALLY like to see the recording being possible when the Edit Layer B button is blinking, storing the played sequence into both layers at the same time.... please.
