Sorry to hear you're having trouble with your Rev2. The first thing to check is to make sure you're plugged into the main outputs, and not the B outputs. If you're plugged into the B outs, you'll only hear the second half of the voices.
The next thing to check is to make sure Multi Mode is turned OFF in the Global menu.
If that doesn't fix it, support will get you going again.
