I always used my tempest as standalone up to today, when I hooked it up to my new ableton-centered setup.. few issues came up and hope someone can help me out:
- non matching tempo: tempest, set as slave, reads a slightly different tempo than the one live is pushing out: 90.3 rather 90 bpm. I noticed A reverse similar issue when using the tempest as a master connected to a matrixbrute: the brute was reading a slightly faster tempo coming in.
- noticeable flange on notes: just to check sync, I recorded a simple bar with a kick on fourths: a clear flange is audible, like the same note is triggered multiple times within a millisecond time frame (I checked, it's not a midi loop issue). No problems at all with the other synths hooked to ableton.
Thanks in advance for your help: also If you found a specific strategy for the tempest/live that in your opinion works well, please share ^_^
