Hey all,
I figure I'm probably doing something idiotic, so I figure I could come to you with this issue before asking for tech support.
I've been learning my new DSI Rev2 (it's a wonderful instrument), and have started to get into integrating it into my workflow, which uses FL Studio as a DAW.
The root problem I have is that something very peculiar occurs when you start or stop playback in the DAW: The patch gets altered and becomes supremely 'tinny.' I opted to verify this wasn't some setting issue, so I blanked out a patch and used the canned, generic, default patch you get from Global->24. Basic Program and writing that default to memory (hitting write again). Then I just hit 'stop' on my DAW and poof. It goes tinny. If I switch to the next program, and then back, it goes back to normal.
https://soundcloud.com/formulaxfd/dsi-rev2-oddproblem/s-TvFnFNow, in order to prove this is a DAW problem and not a Rev2 problem, I tried this with Ableton. It still does it. I tried it with my Kawai ES100 ... it still does this behavior.
So at this point, I'm down to 'something isn't right with my Rev2.' I've gone through each MIDI setting, and the only thing which stops this from happening happens to make the instrument not respond to *anything* MIDI.
What am I doing wrong, or have set wrong?
