Local Control DAW Issue
« on: July 27, 2017, 06:57:13 AM »
Hi Guys
When i'm using Ableton with the Local Control off there some parameters that don't work, for example I'm unable to use the filer cutoff, I have to turn the local control back on for the cutoff to work! The same goes for a other knobs and buttons, Local control seems to disable any control of the synth when connected to a DAW. Am I missing something here?
Synth Arsenal - Access Virus TI Polar, Moog Sub37, Nord A1, Nord Wave, DSI Prophet REV2, Roland TR8, Ableton Push 2
Re: Local Control DAW Issue
« Reply #1 on: July 27, 2017, 07:14:13 AM »
« Reply #2 on: July 27, 2017, 09:12:52 AM »
Smoke this thread over:
http://forum.davesmithinstruments.com/index.php/topic,1696.0.html
Seems it s a bug.
thereīs a bug regarding the pedal/CV foot control not sending midi control data if local control is set to off - but thatīs not affecting other parameters like cutoff.
MacPro 5,1; MacBook Pro
« Reply #3 on: July 27, 2017, 09:16:57 AM »
Hi Guys
Maybe in the midi settings of Ableton something is not set properly. Incoming midi data should go midi thru to the midi output where your rev2 is connected. Or try to change the global settings (6. MidiParamSend / 7. MidiParamRcv) to send / receive "cc".
« Reply #4 on: July 27, 2017, 12:01:55 PM »
Proton is correct. Ableton, much to the dismay of many people, does not work natively with NRPNs. Because our synths have so many parameters we utilize NRPNs to allow MIDI control of every param. Set MIDI Send and Receive to CC in the Global menu of the Rev2 in order to communicate with Ableton.
SEQUENTIAL
