Strange filter 2 behavior
Started by particlesintowaves, July 11, 2017, 04:15:57 PM
42 Replies 109,893 Views
msflsim
Commerce
The thing is that I can get F1 to fully close by running the calibration a few times, F2 never really closes and the cutoff is not as smooth as F1. F2 when sweeping has a point between 100 and 130 where there are no changes in sound.
drxcm
Commerce
Brand new Pro 2 just opened today and seeing the same behaviour here.
Tried running the filter calibration but no change.
Have emailed support - any other suggestions?
drxcm
Commerce
When i find the solution i'll post it here, seems like afew others on here have had the same issue but no followup on what fixed it..
A temporary frustration with my brand new Pro 2 I hope!
grunes
Commerce
drxcm FYI the debug menu can be accessed by pressing 'Octave Up' and 'Down' buttons along with 'Global' at the same time. Just be wary while in this menu page.
drxcm
Commerce
Quote from: grunes on January 24, 2019, 10:49:25 PM
Thanks, but what do i do in the debug menu to fix this?
msflsim
Commerce
Dsi claimed that the filler tuning inconsistency  was fixed but it is not. I tried to calibrate my filter a few weeks ago and afterwards F2 wouldn't close fully.
I must've ran the calibration unsuccessfully 10 times and then randomly it went back to closing fully.
Quote from: drxcm on January 24, 2019, 06:22:33 PM
grunes
Commerce
1. I would do as DSI recommend on this post https://forum.sequential.com/index.php/topic,2742.0.html
2. If previous suggestion fails I would set every knob/button to it's minimum/default position then try again.
3. If above suggestion also fails then go into the debug menu Clear Calibration and try again.
I myself have not noticed this problem. As you can read, people have had a hit and miss experience. However, upon delivery of my Pro2 it  did need calibrating straight out of the box which I did. Good luck.
drxcm
Commerce
Quote from: grunes on January 25, 2019, 02:45:34 AM
Thanks. None of this has worked. Interesting that the thread you posted saif the bug was fixed ina beta OS but I'm running the latest OS and its still there.
I'll wait to see what support suggssts
cbmd
Global Moderator - Sequential
Full Member
To note, due to the filter's different topologies, filter 2 will never cut as much low end as filter 1.
There is danger in users presuming that the filter's expected behavior is related to a previously resolved bug.  Please contact us directly in this regard so we can assess whether the synth is working correctly or not.
Product Designer
drxcm
Commerce
#29
Ok, so I've been in touch with support.   My issue was identical to the video posted earlier in this thread.
The advice provided by Sequential support was quick and helpful, but did not resolve the issue without my own experimentation.
It was only after considerable experimentation that I was able to get the filter 2 cutoff to behave what I presume is correctly.
The initial advice was to run the filter autotune with the F2 cutoff and resonance knobs fully counter clockwise.  This initially produced a dead zone between fully counterclockwise and 11 oclock, but addressed the strange bipolar issue I was having.
Then this advice was corrected, and I was told I should instead have run it with those knobs fully clockwise.  I did and this  reverted the behaviour to the original problematic state.
Running the calibration did not consistently reproduce the above behaviour.  It was very hit and miss.  Sometimes no effect, sometimes a big effect on the knob behaviour.  Nothing consistent.  Even when clearing the calibrations in the debug menu first.
I eventually got to a good result, after a lot of experimentation, with the following routine:
I cleared the calibration again.
Then ran the filter autotune / calibration with F2 cutoff / resonance knobs fully counterclockwise
This got rid of the bipolar behaviour in my video, and reproduced the pot's dead zone from fully counterclockwise to noon before the filter audibly started to respond (ie where I got to the first time).
This time however, each time a calibration was run resulted in successive improvements in the response.
The first run resulted in the bottom 1/2 of the filter pot travel being "dead"
The second run resulted in the bottom 1/3 of the pot travel "dead"
The third run resulted in behaviour "within normal spec" with the far ends of the pot travel being relatively symmetrically dead but the pot working correctly.
Seems to be acceptable in terms of functionality at the moment, but I'm not sure now if it's "normal" or not.
aukleive
Commerce
#30
Hi, received my brand new Pro2 a few days ago, updated it to the latest OS (1.4.0.1)...I had the issue from video 2; low/high/band/notch all have the same behaviour on each side of the midpoint..meaning all the sounds I have made so far are probably wasted if I ever get them to behave correctly...
After running the filter calibration several times (and before this in the debug menu: first 7)initialize calibration then 1)clear calibration) I had one pass when filter2 was almost working as expected...
But the real change came after a calibration that didn´t work (back to the same old behaviour), but then I calibrated the Wheels, and just wanted to check...and all of the sudden filter2 was behaving completely superb, even from top to bottom in all modes...
Very, very strange!!
But anyway, it worked for filter2.
However, filter1 now does not output any sound before the pot reaching about 54. From 54 and up it seems to behave normally. Also the graphical display shows the filter stops around midway down...However, watching the meters in my DAW, the moving of the pot between 0-54 outputs, presumably, very low freq sound...back to beta-testing :(
UPDATE...and the first pass of the filter calibration returned me to the exact same bipolar situation on filter2 as before :-[ I´m amazed (sort of)
aukleive
Commerce
#31
UPDATE 2
After almost giving up, I gave the calibration a shot with both the cutoff and resonance set to maximum on both filters...that did the trick for Filter2...
Filter 1 still has this strange output of very LF sound while moving the cutoff pot from 0 all the way up to 39 or so when it starts to output audible, normal sound...I can hear small LF-pops in my subs at ridicolous listening levels between 0-39...
Thanks for a great, great instrument (when it works properly ;-)
best regards
Audun K
Norway
pluc
Commerce
#32
hi,
any news on filter 2 issue?
i am experiencing the same problem, and i think this is oddly related to my sliders misbehaving.
only way i succeded getting filter 2 working correctly is recalibrating my sliders before running the filter autotuning process.
it appeared during this process that my sliders can be glitchy when i tap them at the lower bottom side (~1 time every 10 taps).
also in the calibration process the lower side of the sliders can display weird values, leading to a faulty calibration.
once i tried a slider calibration trying to avoid this behavior and crazy values, filter autotuning worked and i got back my filter 2 working.
anyone?
bobby
Commerce
HI All,
I am also having this issue.   I'm in contact with support who want to send me a new main board.  Have any of you solved this issue via board replacement?   @bongmystic I know you said that you did not...
@pluc,  I notice the same thing with slider value jumping, but calibrating the sliders doesn't seem to net any improvement for Filter behavior :(
tommy
Commerce
I just bought a used Pro 2 and I have the same problem with filter 2 as msflsim  "...F2 never really closes and the cutoff is not as smooth as F1. F2 when sweeping has a point between 100 and 130 where there are no changes in sound".
I have tried initializing, clearing and calibrating the filters many times
Is there a solution for this problem?
Thanks !!
tommy
Commerce
I have been talking to Sequential support and they have told me that I have to send my PRO-2 to repair my filter 2.
Sequential support has been very quick and kindly to reply and propose a solution.
Thanks !!
msflsim
Commerce
So are Sequential finally admitting that the issue is hardware rather than software?
I've run into this problem many times and the solution is random every single time. Sometimes I have to run the calibration 15 times before I get "lucky" and filter 2 works properly and other times I only need to run it 2 or 3 times.
Quote from: tommy on January 09, 2022, 03:15:10 PM
Thanks !!
acemonvw
Commerce
Hi all,
I just purchased a Pro-2 recently and had the same issues as shown here (especially the two upper bumps when cutoff was around 100-130). I have calibrated again and got it to basically close down fully, but at around 12 oclock.
I asked sequential what I should do to resolve this, but so far the only response has been to send it in. I'm a little surprised that they didn't request:
1) To see and hear exactly what behavior my Pro-2 is experiencing.
2) To provide me with a specific calibration SOP (They just asked if I did what was in this forum thread and did it work, after I sent them a link to this thread).
I'd really rather not send in the whole synthesizer (I previously was able to send in a Prophet 12 PCB when they needed to look at it).
I don't know if the merger with Focusrite plays a role, but I'm a little baffled with the replies.
So do other people find that the 'normal' behavior is that there's a linear reduction in cutoff as you go from 100% to 0% on the knob (i.e., from max to min). Mine goes from max to min from about 4 o clock going counterclockwise to 12 o clock, and then nothing.
I know the potentiometer is working because when the two filters are linked and I twist that knob, I can hear changes in the cutoff as I go lower than 12 o clock.
BT
Agents
Jr. Member
Hi there. Nothing has changed in terms of our USA-based support re:FR purchase, just so that's clear.
It's possible the support person you've corresponded is less familiar with the discontinued Pro 2, however. There are many instruments to master here. I can surmise someone might have asked for the full unit because the issue could conceivably be located on the main board OR the panel board.
Generally, if you encounter Filter 2 cal issues on the Pro 2, try calibrating with the Filter cutoff pot set fully clockwise. Do not set it to the center position.
If fully-open calibration doesn't do the trick, try setting Filter 2's cutoff fully counterclockwise and calibrate again.
BT
Agents
Jr. Member
#39
Looks like the person you've been talking to has actually been here for many years - they definitely know the Pro 2. Have you had a chance to respond to the ticket? Any luck with my advice offered above? I have a Pro 2 myself, and am quite familiar with it.
We just want to make sure your issue is handled in a helpful and timely for you.
