Hello all, I just got a Tempest a few days ago and I'm still learning how to navigate by reading the manual, reading threads and watching DSI tutorials. Everything seems to be pretty simple, except when I try to control the Tempest from my MIDI controller.
I believe I've got all my setting on the Tempest as they should be. On the Tempest, I've got Midi Synth IN Channel set to Channel 1, and MIDI Synth Sound set to the pad which I want to control, and that pad is set to 16 tunings.
The problem I'm having is that the controller will play SOME notes, but only a handful. Also, they do not correspond to the physical notes being played on the MIDI controller. Very strange.
I'm using the AKAI Advance 49 as my MIDI controller (MIDI out set to B-1 which sends MIDI out the MIDI port, A-1 is reserved for USB), but to troubleshoot I tried controlling with my Roland JX-3P and get the same results.
Am I missing something simple? Has anyone had the same or similar thing happen?? and if so, how do I remedy this??? I purchased mine new, but it was a floor model at a reputable shop, just wondering if there's something wrong with the unit, or if it's just user error.
BTW I am running OS 1.4, which is what was loaded on the unit when I purchased. I did see that there's a 1.5 out now but I couldn't find where to download.
Any and all help is greatly appreciated!!
Thanks in advance!
