I've discovered a few issues on my Rev2 and wondered if it was just me, or if others encountered these problems.
I'm on the latest firmware v1.0.7.2.
Issue: 1. If I select a basic program and then select the Pulse wave as on an oscillator, it doesn't sound like a Pulse at all.
It sounds really nasal, almost like a pulse would sound if shape Mod was applied.
To get the Pulse to sound like a Pulse, I have to turn the shape mod to 50% - surely this shouldn't be a requirement from a basic patch, you shouldn't have to shape mod it to sound like it should sound to begin with.
This I feel is just a wrong default in the OS that could be fixed with an update, but my other issues are a little more disconcerting.
Issue 2: I have a similar issue (but not the same as) the issues described in this post...
http://forum.davesmithinstruments.com/index.php/topic,1573.0.htmlBasically if I select a triangle wave for my oscillator random notes in the bottom octave of the keyboard will intermittently play a sawtooth instead.
Issue 3: This is the big one...If I create a Basic Program and select the Pulse wave on an oscillator, Notes played at the lower octaves of the synth are intermittently dropped and don't sound at all!!!!
Obviously that's not good!
I have tried recalibrating the oscillators and filters using selection 26 in the globals menu, but to no avail - the issues still occur.
A short video showing the issues can be viewed below...
https://youtu.be/1dZM2hYa2qI
