hi all, i picked up my Prophet 08 module today and noticed i heard what sounded like something inside the unit. it doesn't sound metallic like a screw, but perhaps a piece of plastic. it also doesn't seem to "travel" around inside the Prophet, meaning that it doesn't slide from one end to the other when i rock it from side to side, but there is certainly something going on in there, clicking against the chassis when the unit is moved. i'm not shaking it, just gently moving it up and down.
if anyone has a P08 module and would be so kind.. does this happen to you? it could just be a cable inside, but it does worry me a little. should this not be happening?
also.. my module wobbles a bit. it seems the right bottom leg is a bit short. is there any way to correct this other than gluing something to the bottom of that particular foot? i'd much rather not do that but i can't think of another way. if anyone has any advice i'd sure appreciate it.
