And also... nice move buying a synth for "educational purposes." I've done that before. Wink wink.
Quote from: chysn on June 10, 2017, 05:44:53 AMAnd also... nice move buying a synth for "educational purposes." I've done that before. Wink wink.Has anyone here tried this line with their significant other? I'm willing to give it a go if it nets me something good in return. High risk, high reward!
Just be prepared for the infamous chip breakdown of this synth... they are covered in a resin that makes them heat up and start failing... it WILL happen at some point in time, unless you have it exchanged with the clone chips you can buy these days...
Quote from: Razmo on June 12, 2017, 11:41:46 AMJust be prepared for the infamous chip breakdown of this synth... they are covered in a resin that makes them heat up and start failing... it WILL happen at some point in time, unless you have it exchanged with the clone chips you can buy these days...The Analogue Renaissance clones are now every bit as good, especially as regards the filter resonance tracking that was identified with previous versions; I replaced all six / three of mine for consistency's sake, and the unit sounds great!Also–do not fail to consider the HS-60 / Juno-106S units; the built-in speakers can be quite handy (though I ended up replacing the drivers on my HS-60), and they don't affect the sound quality of the main outputs.
Quote from: DavidDever on June 12, 2017, 01:38:00 PMQuote from: Razmo on June 12, 2017, 11:41:46 AMJust be prepared for the infamous chip breakdown of this synth... they are covered in a resin that makes them heat up and start failing... it WILL happen at some point in time, unless you have it exchanged with the clone chips you can buy these days...The Analogue Renaissance clones are now every bit as good, especially as regards the filter resonance tracking that was identified with previous versions; I replaced all six / three of mine for consistency's sake, and the unit sounds great!Also–do not fail to consider the HS-60 / Juno-106S units; the built-in speakers can be quite handy (though I ended up replacing the drivers on my HS-60), and they don't affect the sound quality of the main outputs.Yep... I replaced two in my MKS-30 when I had it... could not hear any difference... exept for the difference that should be there in analog
Quote from: Razmo on June 12, 2017, 11:41:46 AMJust be prepared for the infamous chip breakdown of this synth... they are covered in a resin that makes them heat up and start failing... it WILL happen at some point in time, unless you have it exchanged with the clone chips you can buy these days...I got a refurbished one, even with a new set of sliders free of crackle, the only thing it is missing is new-car-smell...
it's just nice to know this if you start to hear crackling someday...
