How to use tap tempo ?
« on: June 08, 2017, 10:00:30 AM »
Can't figure out how to use the tap tempo on the Tempest.
How to have it working?
Tried several combination of keys with shift and so on, had a look in the manual, searched the forum, but couldn't find any info about this.
Might be simple answer but if somebody can help me, would be great.
RobH
  • 464
Re: How to use tap tempo ?
« Reply #1 on: June 08, 2017, 11:09:51 AM »
Tap Tempo behavior: Shift On + Play, Shift Held + Play—With Tempest’s
default behavior (Shift Held + Play), must be held to tap the tempo. Otherwise,
5
Play starts/restarts the Beat, whether Shift is on or not. When set to Shift On +
Play, Play is used to tap the tempo when Shift is either on or held down.
This is from in an additional manual pdf found here
https://www.davesmithinstruments.com/downloads/tempest/doc/Tempest_addendum_1.1.pdf
« Reply #2 on: June 11, 2017, 11:24:15 AM »
Finally got it to work. Thanks
LucidSFX
  • 302
    • Soundcloud
« Reply #3 on: June 11, 2017, 07:21:00 PM »
I would say your welcome but I didn't help. I just wanted to break the 200 post mark;)
Glad it worked out for you!
LucidSFX
current hybrid setup
2 x Technics 1200 MK7
Allen & Heath DB4
Allen Heath K2
Tempest
VirusTI2
RME UFX
Adam A7
SP2400 (on order)
Glenlivet 18yr scotch
