Hi there,
I'm having some issues recording parameters from my Pro 2 in Logic Pro.
At first, i was noticing that whenever i turned a knob on the Pro 2, no matter which it was, it was being registered in Logic's Midi Activity display as the same controller, number 38.
I.E. I would turn the Filter 1 Cutoff knob, and Logic would recognise it as receiving control number 38. I'd then tweak the Filter 1 Resonance knob, and it would still recognise it as 38. This was causing all sorts of issues when recording parameter changes into Logic in real time. I also checked this in the Midi Monitor app, and got the same results.
I then found that in the Global menu on the Pro 2 i could change the MIDI Param Send and Receive modes from NRPN to CC. So i tried that, and Eureaka, i could now record different parameters separately into Logic.
However, I've now noticed that not all parameters on the Pro 2 are registered at all in Logic. For instance, Logic doesn't recognise any incoming Midi data when turning any of the Filter 2 envelope knobs, or any of the LFO section knobs.
So i feel like i'm "halfway" to where i want to get, which is to be able to record any of the Pro 2's knobs in real time in Logic.
Does anybody have any suggestions in what i might be doing wrong here, or is this just a limitation of the combination of the Pro 2 and Logic?
I case it helps, I'm running Mac OS 10.12.4, with Logic 10.3.1.
Thanks in advance for any suggestions.
