Rev2 or OB-6?
dsetto
  • 388
Re: Rev2 or OB-6?
« Reply #20 on: June 06, 2017, 09:55:49 PM »
What can't the OB-6 do that may be a deal breaker?
What one or two things can the Rev2 that are deal-makers?
So far, I'm feeling you want the OB-6.
Your Radias is in ballpark of Rev2. That plus the deep synthesis in the Pro 2-Modular land is enough synthesis to occupy you substantially. Put your next studio energy toward flavor.
Good luck.
Re: Rev2 or OB-6?
« Reply #21 on: June 07, 2017, 04:43:50 AM »
Good luck.
have GAS for a pro 2; feel it would be a perfect companion for the rev2 :D
Re: Rev2 or OB-6?
« Reply #22 on: June 07, 2017, 05:12:10 AM »
I would say go to the store and initialize a patch on each one and see how you feel sculpting your own sound and how you interact with the layout.
What's important to you? The features or the sound?
Re: Rev2 or OB-6?
« Reply #23 on: June 07, 2017, 05:47:50 AM »
feel like a decent musician can make almost anything sound good; remember stories of beck rocking a party with a squier stratocaster played through a boombox
Re: Rev2 or OB-6?
« Reply #24 on: June 07, 2017, 09:06:02 AM »
Yeah but again that comes down to personal taste and I'm sure that wasn't Beck's only sound.
« Last Edit: June 07, 2017, 09:08:13 AM by LoboLives »
Re: Rev2 or OB-6?
« Reply #25 on: June 07, 2017, 03:05:35 PM »
That's interesting. I've always thought of the Radias as more OB-like in its sound due to it's filter range. But it's more Rev2-like in it's programming horsepower.
DSI Pro 2 | Yamaha MODX 6 | Volcas: FM2/Kick  | Roland JU-06A | 104HP Eurorack | Arturia Drumbrute Impact | Eventide H9 | EHX Grand Canyon | iPad
dsetto
  • 388
Re: Rev2 or OB-6?
« Reply #26 on: June 07, 2017, 05:19:50 PM »
I was referring to programming prowess. I have very little sense of the Radias. And with the little sense I have of it, I would think the Rev2 is in between it and the OB-6 in terms of timbre. So disregard that last thought as speculative.
Re: Rev2 or OB-6?
« Reply #27 on: June 13, 2017, 06:22:25 PM »
Any Rev2 owners experimenting with the audio out mod source in the mod matrix? I'm wondering if you can modulate the oscillators and get into OB-6 X-Mod territory.
Re: Rev2 or OB-6?
« Reply #28 on: July 03, 2018, 05:52:40 AM »
I ended up choosing both and my OB-6 keyboard should arrive in a week. Needless to say, I've spent hours reading forum posts and watching YT.
DSI Mopho SE / DSI Prophet Rev2-16 / DSI OB-6 / Roland D-50 / Roland Juno DS88
Re: Rev2 or OB-6?
« Reply #29 on: July 04, 2018, 11:22:36 AM »
I've had both Tetra, and the REV2 right now... There is not really much to be comparing the REV2 with the Tetra for in my opinion... the only thing that the Tetra's have that the REV2 do not is the COMBO/MULTI modes, and the analog feedback... other than that, they sound the same to my ears... the REV2 though is much more hands on, has digital FX onboard and it's synth engine has been extended with more modmatrix slots etc... and with a 16 voice REV2, the problem with voice stealing is a lot less than an 8voice paired Tetra.
Comparing it to an OB-6 I can only do when it comes to the videos I've seen of it, and comparing the synths engines. Engine wise you'd be stupid not to choose the REV2.. .it's soooo much deeper and featured than the OB-6 in any way, and it's not even necessary to compare it... this is a simple fact... the only real goal in a comparison is the filter and oscillators, and in that case, the OB.6 will win in most cases... that is where the choice becomes hard, since that should be a rather important factor.
Also how would you use the synth?, will you go deep in sound editing?, what types of sounds do you want from it... THAT is what you should make your choice around... 6voices is not much unless you generally use sounds with a relatively short release, and you go for mainly bread and butter synth sounds... if you need complex pads or other sounds, you'll quickly run into problems in the sound design... that is where the REV2's deep engine comes in handy, especially the stacking feature of the two layers is more important than you would think, and what makes truly outstanding sounds possible with the REV2... plus the addition of the internal FX which will give you a much broader stereo perspective in contrast to the Tetras... the OB-6 have about the same FX though and has two of them on it's only layer... REV2 it's ONE FX per layer which can be a little limiting compared with the OB-6 though.
So consider what you'll use it for... you already know how they sound in comparison and prefer the OB-6... if you do not necessarily need the strenghts i mentioned about the REV2 compared to the OB-6, then certainly you should think about getting the OB-6... if not... then REV2.
My 2 cent.
« Last Edit: July 04, 2018, 11:27:33 AM by Razmo »
