Effects signal path
Effects signal path
« on: May 25, 2017, 09:24:54 AM »
The question is: Full Analog signal path and digital effect in parallel or not? Like P6/OB-6.
Re: Effects signal path
« Reply #1 on: May 25, 2017, 10:11:21 AM »
This is correct. The dry/wet mix is controlled by an analog VCA, so unless the FX mix is at 100%, there will always be some of the pre-FX analog signal there. This goes for both the Layer A and Layer B effects, as they are processed independently.
SEQUENTIAL
« Reply #2 on: June 01, 2017, 07:40:22 AM »
Hello, I have a continued question regarding the effects signal path after reading the manual...
"While the effects themselves are digital, the main signal path of the Rev2 is analog.  The On/Off switch enables and disables an effect, ensuring an analog signal path when off"
Does this synth provide the flexibility to run through the digital effects (when on) and still send the dry/wet audio signal to an outboard effects pedal? (i.e. use the internal chorus with an external reverb pedal)
