All right so I added the ability to randomize it from about 3 dozen scales and chords. I still need to add some dialogs in and maybe later I will change the graphics so it looks better, but you can have up to 256 scenes and you set how many measures you want a sequence to play and it will go through them sequentially. I have the midi setup to my settings in midi.py, you need to change it to your ports. You can use the clock from the mopho itself if you want to, as I use midi clock messages to count which is 24PPQ.
Maybe later will add more functions on building chaining sequences and having the ability to morph, the only problem is if I send to many NRPNs it can sometimes make the sequencer pause for a second.
