Prophet Rev2 Manual
Re: Prophet Rev2 Manual
« Reply #20 on: July 31, 2022, 02:25:20 AM »
I could have written about debug mode, sorry. It's in a separate thread on forum a little bit down.
Had to ask support for it.
LFO1 + LFO4 + Global toggles debug mode menu.
What I looked for was ability like in Take 5(read on forum) copy U1-U4 over to F1-F5.
There is the other way too.
Compared to Take 5, REV2 has plenty space to store own presets to overwrite.
But still it's another 512 that are freed up if there is a reason for that.
For me there is usually way too much effects and stuff on factory presets, so remove that or modify further to liking. I mostly use factory presets to learn nifty ways to modulate stuff to get an effect. Gained quite a lot of ideas examining those. But several really nice as are too.
Among favourites are DubChord on layer B for U1:P101. Removed unison and effect, copied to layer A, modified pan spread in one layer a bit, OSC SLOP different in layers too and almost done activating both layers. Fluffy nice bass with 2 voice unison this way.
« Reply #21 on: July 31, 2022, 09:41:14 AM »
Thanks.  Being able to overwrite the factory sounds is a good feature.  I expect I'll do that, eventually.
I feel the same way about presets, generally.  Some are nice, but a bit over the top and need cleaning up a bit.  Some are not something I'd want, but are interesting to start from, to see what I can make out of them without starting from scratch.  Some are probably best wiped, to make some empty slots.
« Reply #22 on: January 28, 2023, 08:51:33 AM »
« Reply #23 on: January 28, 2023, 10:57:22 AM »
Changes to manual pdf
Is that the User’s Guide Version 1.2.4 Feb, 2021, or a newer version of it?
« Reply #24 on: January 28, 2023, 11:44:23 AM »
It's the same 1.2.4, but a strange link I posted a bit up that is broken so had to fix that or pointless.
« Reply #25 on: January 28, 2023, 12:19:46 PM »
I see.  Thanks.
monsterjazzlicks
  • 20
  • Holly~wuud!
« Reply #26 on: May 18, 2023, 06:28:24 AM »
I have d/l and printed off the Rev 2 manual. It's very clear and having a nice good sized text.
Prophet 16 Rev 2
