Mono vs Stereo Patches
ARNK
  • 124
    • Returning to Zero
« on: May 07, 2017, 06:48:40 AM »
When I think of a monophonic synthesizer, mono patches come to mind (for i.e., bass). Of course the PRO 2 is blessed with stereo outs, and can be switched from stereo to mono. So that leaves me asking the question how you've set things up in your DAW. Do you have the Pro 2 as a Stereo or Mono input? How often do you find yourself going back and forth between the two settings? Can you give one example of when/how/why you might create a stereo patch?
DavidDever
  • 698
  • Audio Software Developer
Re: Mono vs Stereo Patches
« Reply #1 on: May 07, 2017, 07:01:24 AM »
It largely depends on the manner by which you handle ping-pong or stereo modulation delays–if you use the internal delays for either, you run stereo–otherwise, mono makes sense, as there's only one voice (read: filters-to-delay signal path).
« Reply #2 on: May 08, 2017, 10:07:11 PM »
I take a more lazy approach and always leave it in stereo.  I don't find any phasing/cancellation problems recording a mono patch in stereo given the DAW and mixer are digital.  Also, by the time effects are added, it would be very hard to notice any phasing or cancellation at all.  The purist way would be recording the mono patches in mono.  Maybe if a get a little more disciplined . . .  :)
DavidDever
  • 698
« Reply #3 on: May 09, 2017, 04:07:02 AM »
As do I - my remark was more of a nod to those short on mixer channels, or for whom stereo operation is less preferred.
« Reply #4 on: May 10, 2017, 10:09:36 AM »
I go mono into my mixer and DAW. I can't stand ping-pong panning, it just sounds gimmicky to me. And I use external FX instead of the built-in ones on the P2.
« Reply #5 on: May 11, 2017, 02:37:58 PM »
That's a good point.  I feel the same way about the jumping back and forth panning on the instruments.
ARNK
  • 124
    • Returning to Zero
« Reply #6 on: May 13, 2017, 09:54:39 PM »
So you only have the left channel of the P2 plugged up, no 1/4" cable coming out of the right channel? Which DAW do you use?
Do you have the PRO 2 set to mono in Global?
« Last Edit: May 13, 2017, 09:57:18 PM by ARNK »
« Reply #7 on: May 23, 2017, 07:34:24 AM »
Correct, set to mono in global and only using a cable in the Left output. I use Reaper, and a hardware mixer with a few stereo FX boxes on the Sends.
