"Assign mod source" bug?
« on: April 30, 2017, 09:08:09 AM »
On my P12m the "Assign mod source" does not work as expected.
The "Assign mod destination" button works perfectly.
If I start a new patch. Hold "Assign mod source" and press LFO 1 button, it assigns LFO 1 as mod 1 source, perfect. Now if I go to the next row, hold again "Assign mod source" and press LFO 1 (or whatever) it does not select the source.
Long story shot. Shortcut "Assing mod source" + "Source" works only once. Anyone else too? Or just me.
W07
Re: "Assign mod source" bug?
« Reply #1 on: May 01, 2017, 02:10:37 PM »
Yup, it's the same here,
my workaround is, if you then press mod source and another lfo, for example, you only have to navigate one or 2 sources up/down to select it.
Same for destinations that are not on the module front panel, click on the relevant section/item button, and you're already a lot closer.
Sometimes it selects a slot where the source is already in use, that's a bit annoying if you're not paying attention
