Can New Music Be Made with Vintage Instruments?
  • 2168
Re: Can New Music Be Made with Vintage Instruments?
« Reply #20 on: May 10, 2017, 02:56:43 PM »
The Minimoog is still being used to make new music, and so are a lot of other old vintage machines, so that in itseslf should answer the question in an instant... most synths from that time has enough parameters to tweak to allow for very VERY many different sounds that have not been used yet... sure, if you only use the synth standalone without FX for example, you'd be limited with some older synths that do not have that many controls, but still people use them all the time.
with regards to a mellotron, which is a VERY limited-parameter type of instrument, you'd be hard pressed to make that sound new without external FX mangling the hell out of it... I see the mellotron as a form of "Vintage ROMpler" with very few "samples" in it... so I'd keep a long distance from that if it is not to sound "old school" familiar all the time.
« Reply #21 on: May 10, 2017, 08:08:53 PM »
The M4000D does at least have polyphonic Aftertouch.  ;D
You know I am really liking the idea of a M4000D and M4000Mini stack but that's not until way down the road...who knows maybe by then someone while figure out a way to make a new one with tape and not have it be this huge thing...much like T Rex doing a new Tape Echo...hmm..
« Reply #22 on: May 11, 2017, 02:27:53 AM »
These new models certainly have their advantages in terms of reliability, playability, and controllability. You can connect a sustain, a volume, and two expression pedals (one for stepping through the presets) to them, the bigger model allows for individual note articulation with polyphonic aftertouch, you get a huge library of sounds which you can combine in pairs, you can manipulate the pitch, change octaves, and modify the playback behaviour (e.g. the time it takes the tapes to jump back to their beginning), you can control attack and release times, and each sound is instantly available. While almost all of these features are maybe not so special in general, they do enhance the overall playability and can provide the tools for different uses.
It's a speciality, that's for sure. One thing that has always struck me though, is how evocative the Mellotron's sound is. I would even go as far and say that it seems to be one of the main ingredients for many recordings' haunting mystique. And I'm sure that's related to it having always sounded old in a way, like old and dusty shellac pressings featuring orchestral music. Certain King Crimson or Genesis classics simply wouldn't work just as well without a Mellotron. Imagine King Crimson's "Epitaph" being played on a Polymoog, or an ARP Solina String Ensemble, or with just about any random pad sound. I don't think that would work well at all because the latter lack the imaginative depth in sound, as in: "this sounds somehow ancient." And this is not the case because the composition is bad or not universal enough, but rather because the references to old, European music traditions alongside lyrics referring to myths that are all juxtaposed with Rock ingredients seemed to have found its perfect aesthetic equivalent in the sound of the Mellotron. If anything, it shows that a sound can be just as essential as a composition itself.
« Reply #23 on: May 11, 2017, 09:58:38 AM »
Agreed. There's something that a Mellotron sounds like that most ROMplers or Samplers don't. I would actually prefer to use it over my Kurzweil for most parts. Some of my favorite scores have incorporated a Mellotron amongst their organs/synths and pianos and I think it really does give a haunting score. Almost like an old old wax record that's badly damaged and crackling away and warping. Phantasm, Maniac, Zombi 2, Suspiria, all soundtracks that were hugely influential to my introduction to synth work all included the Mellotron usually for the low male choir, flute, pipe organ and string sounds.I would love to be able to own one but highly expensive for what it does.
« Reply #24 on: May 11, 2017, 02:08:58 PM »
The Prophet '08 can make a very impressive mellotron strings imitation.
