Prophet 12 Beta 1.4.2.3 Screen Saver!
DiScO
« on: April 12, 2017, 11:26:46 AM »
Hi Folks,
Just a heads up if you're updating to make sure the screen saver is not active before starting the update or you won't see the countdown! Not sure if the screen will automatically switch on after the countdown sequence has finished (after reboot I guess) but it's the not knowing in between! Perhaps it was just mine that stayed off when starting the OS transfer but just wanted to let you all know incase you can't see what's going on. Cheers.
