More actual images:
Looks good so far:
- 4 different synth engines (wavetable synthesis based on Nave, including its speech synthesizer, VA, granular sampling, and a resonant filter bank as it is known from physical modeling, although the latter is not the goal of the designers - at least not in terms of emulating strings, etc).
- 6 LFOs and 6 envelopes
- color-coded LEDs indicate modulation and signal routings
- TP-8 Fatar keyboard
- freely assignable voices for bi-timbral mode (4-4, 3-5, 2-6, 1-7 and vice versa)
What has yet to be seen is how far the sampling option goes, i.e. whether the Quantum could also technically be used as a traditional sampler.
Rolf Wöhrmann indicated that after reading through the forums he might now think about implementing more timbrality, maybe 4 times, maybe even with the according physical outputs. But he has to look into that. Interestingly, the "Digital Former" section seems to be very much inspired by the Character Section of the Prophet 12 and Pro 2. At least, it's supposed to do pretty much the same, just after the filters this time.
